Network streams vs TCP-IP with GSM module
Dear LabVIEW community!
I need to transfer data from cRIO target to host PC via mobile internet, provided by GSM module, connected to cRIO chassis.
Which mechanism will be more suitable for it - simple TCP/IP, or Network Streams? I know, that Network Streams, basically, use TCP/IP as a base layer; and they are easier to use; but will there be reliable communication for data transfer, which will be acquired from 16 channels, 50 kHz?
Thanks in advance!
(3,608 Views)
Not sure why you think streams are easier to use.
If so, the difference is only slight.
I would use TCP/IP and have more flexibility and control.
Steve Bird
Culverson.com
LinkedIn
(3,580 Views)
I've used Network Streams to send 16 channels of A/D data at 1 KHz -- it was easy to set up and to use.  I don't know how fast I can push data through Network Streams, but I would guess that the data rate for both Network Streams and "pure" TCP/IP would be similar.
Bob Schor
(3,550 Views)
16 channels at 50kHz is quite a lot of data to push over a mobile connection - have you done any sort of speed-test to see what upload speed you have on your GSM module?
Assuming you're transmitting DBLs, that's 16x50,000x64 bits per second which is about 6MB/second (if my maths is correct!) and that doesn't include any overhead of the structure of the DBLs (e.g. as an array) or the messaging format you're using. I think you'd need at least a decent 4G data connection to be able to transfer that much data - and obviously that would be subject to drops in connection or changes in connection speed (e.g. if someone walked past or because of weather conditions...mobile data connections can vary quite a lot).
Of course, your connection between your cRIO and the GSM module also needs to be fast enough for that much data! (a lot of these GSM modules are connected via serial/RS232).
You might need to buffer the data locally on the cRIO (e.g. on a file) and then try to send the data when you can in batches to the PC. Even if you do get a decent upload speed with your modem, there will still be significant latency/jitter in the connection (expect it to take around 50-200ms to transfer the data).
It might be doable...but to me it sounds like you're sending way too much data for a real-time/live connection (just based on the maths above and a rough idea of mobile data connection speeds).
(blog)
(3,518 Views)
