Neural network toolkit
Hi to all, the thing here is that I need a good neural network toolkit for LabView2013. Some versions that I downloaded were not compatible with 2013 version.
I would very much appreciate your help.
Cheers
(2,680 Views)
There are a few toolkits, which ones did you try? 2013 is very old, though. From what I found, typically you need at least 2016.
(2,629 Views)
I downloaded the ngene and piotr version. I resolved the issue by installing labview 2019 and installing ngene version. Thank you very much for your response.
(2,579 Views)
