New Control Labels are bolded
I place a new control on a front panel and the label is bolded. It just started doing this so what did I do to cause this?
I have worked in Labview for years currently using Labview 7.0.
Message 1 of 11
(7,290 Views)
some fonts are set depending on how they are in windows settings (assuming Windows OS).. Check on these settings
Also, in Labview menu, select
Tools
Options and then make sure the fonts are not set to bold. You may have pressed some keyboard key that automated that
Message 2 of 11
(7,290 Views)
Already checked Options/Fonts and they are still default in Labview. Using Windows 2000 where would you think to could look? The label font is the standard Labview application font but is bold,
Message 3 of 11
(7,290 Views)
Go to
Tools>>> Options >>> Font
Select application font.
click Font Style
Click panel default
ok
ok
drop a new control.
Ben
Message 4 of 11
(7,290 Views)
Once you checked that the LabView fonts are set to "plain",
Tools>>>>Options>>>>Fonts>>Font Style
then the issue should be solved.
If not, go to windows settings>>>appearance
Then select the item# icon, menu, menu bar etc..
I am not sure which is the one to check,
but, for each item selected, check on the corresponding font that it is not set to Bold
Hope this helps
Imad
Message 5 of 11
(7,290 Views)
Tools>>>Options>>>Fonts are all use defaults. Changed this for application font and it changed the VALUE part of the control but not the label. Changed it back no effect and it still bolds the labels
Appearance settings are the same as another windows 2000 system which does not bold label when controls are placed on front panel.
Any other ideas?
Message 6 of 11
(7,290 Views)
It worked! Thanks for your help. Tried everything else in the Font options but this.
Message 7 of 11
(7,290 Views)
> options but this.
I'm coming in on this late, but I'd guess that what was actually changed
was the Current Font definition. If you select something and change the
font, you apply it to the selection. If nothing in selected, you are
changing the font specification that will affect things that adapt the
current font, like free labels and the name labels of controls. So, if
you have nothing selected and you go to the menus and choose Bold,
subsequent free labels and name labels will drop bolded. Ditto for
making the font be Sand or some such. To put it back, have nothing
selected and choose App font or uncheck the other setting.
Greg McKaskle
Message 8 of 11
(7,290 Views)
This just happend to me - 8 years later!
LabVIEW 2012 running in Virtualbox.
The fix: Remove the "B" in the LabVIEW ini file entry: BDFont= "0" 15 B
Not sure how it got changed.
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 9 of 11
(6,698 Views)
... and 9 years beyond that this is still a potential pitfall. Since this is still an issue and since I found the solutions to be cryptic, I decided to add on to this very old post (17 years!).
I just had to solve it in LabVIEW 2020. The default font for new labels will be set to bold if you press CTRL-B with nothing selected. To switch it back, do the same; with nothing selected, press CTRL-B.
Message 10 of 11
(4,585 Views)
