New LV2010 VI: High Resolution Relative Seconds
So, how much does measuring the timing slow down the loop?
Message 11 of 15
(3,269 Views)
I'll get back to that later as time permits.   I'm not really set up to do serious benchmarking but was looking at base quanta for this.  Yes the FB node and the math operation (not to mention dynamic memory allocation and debugging) have considerable impact on the code speed.
Message 12 of 15
(3,262 Views)
Yeah mine is password protected too. I've got something running 2013SP1 I'd like to use it in. Since it's not on the pallet, and I cannot actually look at the VI to copy it elsewhere, how do I actually USE it?
Message 13 of 15
(1,369 Views)
If you open the front-panel of the VI, you can drag the icon (in top right) onto a block diagram. You can do this for password protected VIs.
The easier way is to install "hidden gems" through VIPM, then it will be on the pallet and you can drop it through quick drop.
Message 14 of 15
(1,349 Views)
I also figured out you can take the file (right from the windows folder) and drip the file in the block diagram.
Message 15 of 15
(1,345 Views)
