New Modal Parameters Vis to download link
Sir/madam,
                I need New Modal Parameters Vis to estimate modal parameters.2009 version is not working in 2010.Kindly,send me the link.
(2,475 Views)
hi ,
  Can you post in detail of your problem along with the VI you did so far.
Thanks and regards,
srikrishnaNF
Srikrishna
(2,470 Views)
Sir,
I am doing structure analysis using PXI with 6229 & 4496 and accelerometer from Kistler with Impulse hammer from Dytran.I got FRF data.I want to do modal parameters estimation.I downloaded modal parameters estimation VIs from NI site but it is for 2009 version i found out that a file with name "NEW MODAL PARAMETERS ESTIMATION VIS" is available that work well in LabVIEW 2010.I need that file to get damping in system and other parameters.
(2,465 Views)
