New Thread for Conversion of LabVIEW 5.1 code to 8.5
Hi 7nitride9,
I converted those three files to version 8.2.  ISA command driver.vi needed "Level_0_Parse_Params.vi" and "Command Set Database.gbl."  I didn't see files with those exact names, so I loaded "CCD Level_0_Parse_Params.vi" and "CCD Command Set Database.gbl" instead.
Hope these work for you!
Message Edited by Jennifer_R on 07-25-2008 10:43 AM
Jennifer R.
Message 21 of 88
(2,673 Views)
Hello Mike..
I have a VI in 5.1 version, but I need to open it on 8.5
Could you convert it to me?
Thanks in advance for help
Dan07
Message 22 of 88
(2,629 Views)
Hi Dan07,
Here's the VI saved for LabVIEW 8.5.
Jennifer R.
Message 23 of 88
(2,621 Views)
Hi, Mike.
I have theses VI that are very old. I was not able to open that in LV8.5. Could you convert them to me?
Thanks in advance.
Message 24 of 88
(2,609 Views)
Hi, Mike.
Thanks in advance.
Message 25 of 88
(2,609 Views)
Hi 14142153,
here they are for LV71.
Mike
Message 26 of 88
(2,570 Views)
I tried to read a 6.1 into 8.5.1 and LabView crashes.  I get the following message with the debugger:
Unhandled exception at 0x007513e0 in LabVIEW.exe: 0xC0000005: Access violation reading location 0x00000000.
I could understand some sort of pop-up warning me of a problem but it just crashes.   Do I really need to port to each newer version to get it to the latest?  Please say it isn't true!!
Message 27 of 88
(2,546 Views)
Interesting is further checking, some files made with the same 6.1 version will load directly with 8.5.1.  Crazy tools.
Message 28 of 88
(2,544 Views)
Hi lecroy,
You should be able to open VIs directly in LabVIEW 8.5.1 as long as they were saved in version 6.0 or later.  Any known upgrade and compatibility issues can be found in the LabVIEW Upgrade Notes
Feel free to post the VIs from 6.1 that crashed LabVIEW to see if converting them to an intermediate version of LabVIEW helps.
Jennifer R.
Message 29 of 88
(2,533 Views)
I have a very limited knowledge of Labview and our plant has upgraded our 5.1.1 labview to 8.5
Of course the vi's are too old so they wont even load.
I have attached the vi's in a zip for conversion, any help is greatly appreciated.
Will V.
Message 30 of 88
(2,416 Views)
