New Thread for Conversion of LabVIEW 5.1 code to 8.5
Hi Spiro1,
Keep in mind that upgrading a VI or LLB from one LabVIEW version to another is not entirely seamless - especially when the jump is as big as LabVIEW 5.0 to 8.5.
In order to successfully upgrade your VIs from one LabVIEW version to another, both versions need the same drivers.  For example, if your original VIs involve the Traditional DAQ driver, they won't load into a later version of LabVIEW correctly if you only have DAQmx installed on the newer version.
If you want your VIs saved in a later version by someone else, you need to tell them the drivers accessed by your VIs.  There's still no guarantee of a successful upgrade due to differences between driver versions as well.
Kevin S.
Message 41 of 88
(2,062 Views)
Hi Forum Helpers
I saw that you convert old Vi's to be compatible with Labview 8.5.1. Actually I have a Vi with some sub vi, which have been written in Labview 5.1 and I can not open it with Labview 8.5.1.
I would be grateful if you help me.
Thanks a lot in advance for your favour.
Amin
Message 42 of 88
(2,035 Views)
Hi Amin,
if you post your vi's, then we can help you.
Mike
Message 43 of 88
(2,035 Views)
Hi Mike
The main Vi is ``Ageing test main.vi`` and the others are sub vi.
really thanks for your big favour in advance.
Amin
Message 44 of 88
(2,023 Views)
Hi Amin,
here we go. I saved it for LabVIEW 7.1.
Mike
Message 45 of 88
(2,013 Views)
can someone convert this .llb into a LabVIEW 8.5 for me, please? Thanks in advance.
Message 46 of 88
(2,002 Views)
Hi daniopa,
here they are for LV71 now.
Mike
Message 47 of 88
(1,989 Views)
Hi Mike
Thanks a lot for your favour.
But you converted Vi's for Labview 7.1, Isn't there any problem when I want to load them with Labview 8.5.1?
Best Regards
Amin
Message 48 of 88
(1,986 Views)
Hi Amin,
no there is no problem. LV85 can load them well.
Mike
Message 49 of 88
(1,985 Views)
Hi Mike
Thanks a milion for your super fast reply.
Have a nice Weekend
Amin
Message 50 of 88
(1,983 Views)
