New To Labview Question on interfacing 2 different device.
I'm new to labview and have a few questions. I'm trying to interface two different devices. A rotary stage and a dispensing unit. The rotary stage has a builtin controller and so does the dispensing unit. If I am trying to get both of these devices to communitcate with each other so they start working at the same time how to I do this? Would I need any other hardward?
Thanks!
(4,354 Views)
We need more information like the exact make/model of your instruments and what communications options they have to even begin to answer your question.
=== Engineer Ambiguously ===
(4,337 Views)
I'm using a Performus V (http://www.nordson.com/en/divisions/efd/products/fluid-dispensing-systems/performus-series-dispenser...) and a Thorlabs (https://www.thorlabs.com/thorproduct.cfm?partnumber=K10CR1) Motorized Stage. I hope this helps provide more information for answering my question.
Also, thanks in helping me figure out this issue!
-B
(4,322 Views)
Well it looks like the rotary stage only has and analog voltage input to initiate and end of cycle plus a contact closure.
The Performus V may have some controll ability through it's USB port, but I do not have the time to read the manual for you.
 I would guess you are going to need some sort of DAQ device (even a cheap one like the USB-6009) to read and provide the analog voltages for start and end of cycle plus the relay contact closure.
But I have never worked with either of these devices so I am only guessing.
(4,282 Views)
Did you ever find away to control the dispenser?
(3,646 Views)
