New cRIO with NI 9401
Hi
I am a new CompactRIO user and am trying to test if I am able to generate a signal with my NI 9401 digital I/O card.  I have set up a program in LabVIEW but when I run it and check the voltage to the port when I am sending the signal, I see no change in voltage with my voltmeter.
Help?
(2,864 Views)
I just solved it ... I didn't have the NI 9401 module set to Output 🙂
(2,848 Views)
and it' works now?
(2,575 Views)
Hi SASA,
atleast it worked 6 years ago! Did you notice the age of those posts?
(2,568 Views)
