New copy of array when pass to subvi?
If pass an array to a subvi without processing inside, will it generate a new copy for the array. Thanks.
(2,325 Views)
Accepted by topic author alex.
New copy will not be created if you are simply passing the array but incase if you use a shift register inside the subVI then a copy will be available at the node.
(2,320 Views)
