New in labview: i want send a cluster to a function in c#. I can not.
To .Net Object doesn't work for custom datatypes (unless maybe when they implement some magic .Net class factory of something). You have to create them explicitedly yourself.
using System;
using System.Collections.Generic;
using System.Text;
namespace Test
    public struct Cluster
        public int value;
        public string text;
    public class TestClass
        int test;
        public TestClass()
            test = 0;
        public int Initialize(int sequence, Cluster record)
            test = record.value;
            return 0;
        public int GetValue()
            return test;
This works!
Rolf Kalbermatter  My Blog
Message 11 of 12
(1,138 Views)
And by the way that example has an object leak!
The cluster refnum needs a Close  node too after use!
Message 12 of 12
(498 Views)
