02-22-2007 05:39 AM
02-23-2007 03:16 AM
Hi Kewsvnet
Can you confirm that you are using LabVIEW 8.0 with the LabVIEW FPGA 8.0 module. Are you able to see the cRIO in Measurement and Automation Explorer (MAX). MAX is a low level configuration tool that enables you to view devices connected to your computer and also the software installed. Expand the Remote Systems tree and check whether the cRIO system can be located. It maybe a driver issue that the 'Targets and Devices' category is not locating the cRIO device. Try reinstalling the latest version of the NI-RIO driver.
LATEST NI-RIO Driver download >> http://digital.ni.com/softlib.nsf/websearch/8FBECA88CF87D34F862571C600566283
Although the following articles involves Compact Vision System, it outlines an issue whereby the FPGA device can not be found in LabVIEW. Have a go at the solution and see how you get on.
http://digital.ni.com/public.nsf/websearch/3CD5383DA52F818186257118006C3A8B?OpenDocument
Kindest Regards
02-23-2007 04:48 AM
02-23-2007 05:04 AM
Hi Kewsvnet
So you have tried the device on another machine and it works fine, is it only on a specific machine that this issue is occuring on? I think I misunderstood the issue yesterday, am I right in understanding that when you click on 'New Devices and Targets' absoloutely nothing happens apart from the 'hour-glass' appearing for a while? If this is the case it maybe the case that LabVIEW may have become corrupted in some manner. Repairing it will not solve an issue like this. What you should try is to force LabVIEW to create a new .ini file, which holds all the configuration settings. To do this you need to rename the .ini file so that when LabVIEW starts it will detect no .ini file an create a new one.
The .ini file can be located via C:\Program Files\National Instruments\LabVIEW 8.0\ LabVIEW Configuration Settings (it is a file size in the range of 2Kb - 10Kb)
You need to rename this file 'LabVIEW Backup', then attempt to restart LabVIEW and a new project and try to add a target.
Let me know how you get on
Kindest Regards
YatinM
NIUK & Ireland
02-23-2007 01:32 PM
02-26-2007 02:48 AM
03-07-2007 11:08 AM
07-25-2009 10:13 PM
I am having a similar issue but with labview 8.6 and the same card. Please let me know if you were able to resolve it Kewsvnet!
Brian.
07-27-2009 06:43 AM
Hi Brian,
Its been a while since I had that problem, but if I remember correctly I was forced to do a complete fresh install of Labview and that seemed to sort the problem out. While that is quite a pain to do, I don't think anything else worked for me.
Regards
Kewal
