New to LABVIEW. How can I use one analog channel to trigger acquisiton of a signal on another analog channel?
I am new to using Labview and have been tasked to write data acqusition program for my company. We are attempting to log 6 machines, each with their own asynchronous trigger (I can't use one trigger for all 6 machines). I have the idea to use (for example) ai0 for the measurement and ai1 for the trigger (for one machine), yet I see nothing in the documentation on how this is done. I have tried playing around with the DAQ express VI (I am using Labview7) but still don't see a way to have the setup I am looking for. I'm sure this is a relatively easy question, but I'm unsure where to go to look for an answer. Any helpful pointers or guidance in the right direction
would be very helpful!
(2,511 Views)
If what you want to do is start the acquisition of channel 0 when channel 1 reaches the trigger condition and not start channel 2 until channel 3 reaches it's trigger condition, then no, you cna't do that unless you have multiple daq devices. What can be easily done is continuously acquire all channels and monitor your trigger channels. When the trigger condition is met, then perform the analysis/logging. On the Analyze>Waveform Monitoring palette is the Basic Level Trigger Detection function. Use one for each trigger channel and have it return either the index or relative time of the trigger occurance. This value can then be used to idex that portion of the measurement channel that you're interested in.
(2,511 Views)
