New to system identification in Labview
Thank you for the vi,
I hope we'll get the solution !
Message 11 of 15
(556 Views)
Vincent, were you able to look at this....if not maybe if you could give me some instruction of approaching this kind of problem, in another term, how to retrieve the transfer function from two signals inside a loop , and is it better implemented in the CRIO target CPU or in the FPGA.
Thank you
Message 12 of 15
(538 Views)
E-Warrior
If you use frequencies higher than 10kHz you can't use the ScanMode, you have to implement your code in the FPGA.
If you want to retrive the transfert function inside a loop, i think you should end this loop as soon as you got both transfert functions (if you need the transfert function from two signals).
Hope this helps
Message 13 of 15
(531 Views)
Thanks for ur help though...
Is there anyway, there is a guide, tutorial example in NI for building using the system identification in FPGA if not in the CPU of the CRIO...i tried to do, but to no avail. there is gotta be a tutorial out there.
tnks Vincent
Message 14 of 15
(523 Views)
Hi E-Warrior,
Have you checked the exemples related to the System Identification Toolkit ?
I think you can use it to do your code, and then deploy it to the FPGA.
You'll find these examples by following this path in the example finder : Toolkits & Modules >> System Identification
Message 15 of 15
(513 Views)
