Newbie Question on Autocorrelation/Case Structure
Hello All,
I've looked at the help file for the AutoCorrelation VI and replicated the block diagram shown in the example. I've also replicated the results by using a Simulate Signal Express VI instead of the Uniform White Noise VI (both within while loops). What I cannot seem to do is autocorrelate a real signal (frequency of TTL pulses from a PMT- which ought to be periodic white noise) via a PCI 6602 and BNC 2121. I've essentially wired a DAQ Assistant Express VI to the AutoCorrelation VI inside a while loop (file attached to next post). From the results I'm getting it looks like the program is just treating each new data point as a new autocorrelation instead of doing the sum over all points. I'm convinced its probably a case of me misusing the while loop.
Any advice or observations would be most appreciated.
Cheers,
CJKS
(2,987 Views)
From the VI you attached, I guess what you want to do is online autocorrelation.  The right VI for this is AutoCorrelation PtByPt.vi.  Try to Substitute AutoCorrelation PtByPt.vi for AutoCorrelation.vi.
(2,978 Views)
Dear AOH,
Thanks very much for the advice. At first I thought it was doing the same thing as before (autocorrelating each new data point by itself) but after closer examination its doing it correctly.
Example:
I run the loop once. The DAQ acquires 1 data point. The Pt. by Pt. Autocorrelation VI performs the autocorrelation of that 1 data point over a "sample length" of 100 points. The 200 points of autocorrelated data is all zeroes except for the 100th point.
I run the loop twice the DAQ acquires 2 data points but the Pt. by Pt. Autocorrelation VI performs the autocorrelation of the 1st data point just like before. Then where I would expect a non-zero number at the 300th point (if it were still only autocorrelating a single data point with itself) I find one but also one at the 299th and the 301st point (the value at point 299 and point 300 are equal). I know the symmetry is due to how the VI  is indexing. After checking those numbers manually I find that it is indeed autocorrelating properly (i.e. using both data points).
I think I was distracted by the fact that it kept replotting and scrolling every 100 points.
I'm certain that I'll have more problems/questions as I try to complicate my program! Thanks very much for pointing me in the right direction!
Cheers,
CJKS
(2,966 Views)
