Newbie, Would like to use analog input and graph
I was using the "Real Time Chart.vi" example in Labview 2011 and got it all set up using the random input it comes with. I have a USB-6008 that is set up and I can see the signal in MAX. The big question is how the heck do I get the vi to work with the analog input? If someone could modify the vi and add the AI0 as the input I would really appricate it!!
Message 1 of 27
(3,887 Views)
Down-convert to 8.5 so more can have a look.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 2 of 27
(3,878 Views)
Here you go, Thanks!
Message 3 of 27
(3,860 Views)
Is this the same VI as your original?  Where are your VIs for the instrument?
Message 4 of 27
(3,856 Views)
Aside from me adding the gage and bar graph, its the same as the example. Ive added the AI (purple) channel but I guess I need to add some Daqmx stuff to allow it to connect to the strip chart.
Message 5 of 27
(3,854 Views)
Wheres the analog in channel?  Is this something you haven't posted yet?  Make your changes, then post when you are ready.
Message 6 of 27
(3,850 Views)
here is the vi that I threw together from examples.
Thank You
Message 7 of 27
(3,845 Views)
Sorry, I don't have LV11.  Please down-convert to 8.5.
Message 8 of 27
(3,843 Views)
Message 9 of 27
(3,840 Views)
Your VI is broken.  Create a constant for the History input of your Strip chart property node.
Message 10 of 27
(3,832 Views)
