Newbie - learning how to build triggers in NXG
I have a simple start trigger that is working fine. It starts and then continuously acquires data after the start. In my application I need to start when a signal rises above 3V and then stop when the signal drops back to zero. The length of time between starting and stopping is variable between 0.1 seconds to 20 seconds. It is unknow how long the event being monitored will be until it happens.
How does one create a stop trigger in such a way that the app will continue running and watching for more events?
Message 1 of 1
(1,061 Views)
