Tobias,
Do you mean that you want both counter outputs to change freq and/or duty cycle simultaneously? And to always be equal to one another? If so, why have two rather than one?
On the other hand, if you want your two counter output freqs and/or duty cycles to be variable and different based on the result of control algorithms, I can't understand what you would mean about having them
synchronized. It seems that they couldn't be both independent and synchronized. Exactly what aspect of synchronization do you mean?
Can you describe your app and the function of these 2 counter outputs in more detail? Also, what type of data acq board(s) do you have available?
-Kevin P.
