Newbie question
In general, I would like to create an executable only version of my VI, so I can run this VI without having the developmental version of LabVIEW installed on the PC?
Message 1 of 14
(4,661 Views)
Yes, possible, though LabVIEW development environment is not required on the PC it is run on, LabVIEW runtime engine is required.
Santhosh
Soliton Technologies
Message 2 of 14
(4,645 Views)
You need the application builder to create standalone applications. (included in some versions. What do you have?)
Message 3 of 14
(4,623 Views)
You have to understand lot more on the LabVIEW Environment.
1. You should have a properly structured Project Files mapped with your Developed Code Module, which will look something like below
2.You need to Create Application (EXE)
3.If you want to install in a PC where no LabVIEW Platform (NI Runtime Engine) you should create Installer.
Note: Input to your Installer will be your application.
Check Below image for better understanding.
Note: You should have application builder license to carry out above process.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 4 of 14
(4,551 Views)
Message 5 of 14
(4,509 Views)
hello thank you for the reply.
I have two different LabVIEW developmental installations to work with:
LabVIEW 2020.. Full development system
And
LabVIEW base development system, version 21.0.1f2(64-bit)
Message 6 of 14
(4,500 Views)
And
To use the application builder, you need LabVIEW professional or add the application builder to what you have
You can compare versions, especially the "code deployment and distribution" section here.
Message 7 of 14
(4,483 Views)
The easiest and surest way to find out if you have the Application Builder, is to open the NI Licence Manager and see...
=== Engineer Ambiguously ===
Message 8 of 14
(4,458 Views)
okay thank you very much,
yours was the best help of all
Message 9 of 14
(4,392 Views)
I have LabVIEW 2020,I have a green dot for application builder.
I have a single VI (.vi), I want to convert that to a run time version?
Can I do it?
Message 10 of 14
(4,326 Views)
