Newby question
How do you initialise values to a control array? I want to set all the
values to zero, say, before the program runs.
(3,161 Views)
there are 2 solutions:
1. If you want to initialize your array with some data at the beggining of the program you must use "Finctions->Array->Initialize Array.vi" to fill array with some data. The only thing is that in thic case you will probably need to use local variable of your array.
You can read help about it.
2. If you want your array to be filled with some data every time when you open your VI you must fill the array somehow, right-click on it and select "Data Operations->Make current value default" from pop-up menu. Then you must save the VI and it will have those default values every time you open it.
Example is attached.
This example does the next things:
1. initializes graph with zeroes and waits till the start button will be pressed.
2.
when start button pressed this vi updates graph with some noisy data.
Good luck.
Oleg Chutko.
(3,161 Views)
Hi !
- Type your default value in each element of the array (example 0).
- Then rightclick on each element in the array and select "Save current
value as default value"
This will work
Regards
Magnus
"John Ennew" skrev i meddelandet
news:b03t68$4ak$1@wisteria.csv.warwick.ac.uk...
> Thanks
(3,161 Views)
Thanks.
What if I want to load all the values from a spreadsheet file into a control
array. Is that possible?
"Magnus Johnson" wrote in message
news:npgV9.6360$LY2.376166@newsc.telia.net...
> Hi !
> This will work
> Regards
> Magnus
> > Thanks
(3,161 Views)
John,
Sure. If the reading of the file is the first thing done in your program, then this will be an easy task. That is how LabVIEW loads. It stores a bunch of options in the LabVIEW.ini file. When LabVIEW first launches, it parses this file ans starts LabVIEW with the correct options. You would be doing something very similar.
Also, the way you are aproaching this is exactly what you would need to do if you build your VI into an executable. See this as an example.
Randy Hsokin
http://www.ni.com/ask
(3,161 Views)
Thats all great guys! Thanks a lot....
Just one last question... is it possible to update values held in a control
array whilst a program is executing (other than manually!!), by loading them
from a spreadsheet file?
Cheers for any advice (As you see, I'm quite new to all this!)
"Randy H" wrote in message
news:506500000005000000FEC40000-1042324653000@exchange.ni.com...
> John,
> Also, the way
href="http://pong.ni.com/public.nsf/websearch/BCFF7D3335E256E286256509006772
3D?OpenDocument">this
> as an example.
> Randy Hsokin
> National Instruments
(3,161 Views)
Sure, this can be done. You can just read in the file and parse the data out that you want. Then, wire this data to the indicator terminal or to a local variable for the control.
Randy Hoskin
(3,161 Views)
