Newport XPS controller- RV240PErotation stages via labview
Hi Bill,
It works now. The problem is the Name of Group. The error code -19 means that the group name does not exist. I should use exactly the same group name that defined in the manual configuration. Thanks for your help.
Menglian
Message 11 of 13
(845 Views)
Sorry about that - I didn't see your last post, for some reason or other.  😞
Bill
CLD
(Mid-Level minion.)
Message 12 of 13
(841 Views)
Hi, I have some problem with XY axis (Group Home Search) in Labview. All other groups (ZTT, Theta, Z) are working fine. The sequence is Group Kill, Group Init, Group Home Search, Group Move Abs. In Group Home Search Error 1301 appears. For all other groups these sequences are working well. It works only If I make the initialization »Initialize« and home search »Home« in Front panel (web page of the Standard XPS-Q8 Controller) and after that the moving in Labview without Group Kill, Group Init and Group Home Search . What’s the problem? TNX
Message 13 of 13
(793 Views)
