Newton-Raphson method (or else) for equation sollution in LabVIEW
I have some equations (third and fourth order implicit equations) that I would like to solve, but wouldn't like to mess with them. So i would like a method to simply insert the equation and one of the variables and get the other. This is easy using formula node when the variable i want is in the left side of = but what if it's in the right side powered by two three or more? Has anyone done something like this? I know about GMath toolkit, but is not an option. Sollutions should be available for LabVIEW 5.0.1.
Thanks in advance
Message 1 of 11
(10,127 Views)
Hi Gorka,
Netwon-Raphson is indeed a powerful method for solving equations. In LabVIEW version 6i there is an excellent implementation of this a method along with another method called Ridders algoritm. With this function (Zeroes and Extrema) you not only get one solution, you get all zeros within an intervall!
However, if you are using 5.0.1 maybe you can use a simple implementation of the Newton-Raphson method I put toghether recently. I attach three files; Function. vi which is the VI where you enter your function, Derivative.vi where you enter the derivative of the function, and NewtonRahpson.vi which is the equation solver. You can enter the function using Formula nodes or hard-wire it and the derivatie can be numerically calculated if your functio
n is complicated (just put the calculation inside Derivative.vi). All VIs can be used in LabVIEW versions 4.1 and up.
As I said, this is nothing fancy, but it works really well for my applications.
Hope this helps.
/Mikael
Message 2 of 11
(10,127 Views)
Hey! Thanks for the fast answer (just joking), i finally got it by other way, as i knew there was only one sollution, i selected a range in which the function got from positive to negative, and selected the mid point, if it is positive, take a part of the range, if not, the other one, that way untill the sollution fits in a tolerance.
Anyway, i appreciate your help (four stars for you man)
Message 3 of 11
(10,127 Views)
plz convert this to 2012 labview vi plz i cant open it sir garcia the files you attach function , derivative , and newton raphson.
Message 4 of 11
(9,043 Views)
Coversion request belong in the version coversion forum.
Here are the converted VIs in 8.0, you should be able to open them.
Message 5 of 11
(9,030 Views)
Can anyone help me?
How to find the coefficients of a0,a1,a2,a3 from the below equations using Newton Raphson method
a0+13.2651a1+175.9619a2+2334.1460a3=0.00364764
a0+13.1080a1+171.8199a2+2252.2178a3=0.00360166
a0+12.6566a1+160.1904a2+2027.4717a3=0.00347041
a0+12.5125a1+156.5620a2+1958.9772a3=0.00342877
a0+12.2920a1+151.0922a2+1857.2188a3=0.0033653
a0+12.0977a1+146.3532a2+1770.5298a3=0.00330961
a0+11.9650a1+143.1612a2+1712.9243a3=0.00327172
Brabin
Message 6 of 11
(7,785 Views)
Migth have been better to start a new thread... however ...
This seems to perfect for a linear least square fit, see math/fit/linear fit .. help and examples.
Greetings from Germany
Henrik
LV since v3.1
Message 7 of 11
(7,771 Views)
coffee break solution using the general linear fit
Henrik
LV since v3.1
Message 8 of 11
(7,765 Views)
Thanks for you quick reply....
But using above if i use any four equations out seven, am getting the correct coefficient output.
While using Seven equations the output am getting is not correct
Thank you
Message 9 of 11
(7,758 Views)
Hi Henrick,
Thank you very much.
The VI which you provided is working fine.
Brabin
Message 10 of 11
(7,735 Views)
