Ni-488 Command requires GPIB Controller to be Controller-In-Charge
I need your help, please! I added some cases to a case structure and my program is working fine. When I want to rebuild or build a new exe, I got attached error message. The solutions mentioned in this and other plattforms didn't help. I don't know what to change because the program is working fine, only I cannot build Smiley Frustrated
(5,329 Views)
Hi Susanne,
the error is described very clearly in the upper part of your image.
And (I guess) you already have been told to differ error numbers from error messages. Even when a possible error source might be a GPIBinterface it will certainly not apply when you start the AppBuilder!
I knew we ALREADY had that discussion! Do you ever learn from answers given on your questions?
(5,317 Views)
OMG - how polite you are!
As I said, I did a rebuild! I have never changed the build properties.... and of course, I made a helping document for building exe to not forget what folders etc I need for my build.
(5,303 Views)
Accepted by topic author Susanne1709
Thanks to NI Support! There was one folder which had references which are no longer available on the hard disk. I refreshed this folder and the rebuild was working Smiley Happy
(5,281 Views)
Hi Susanne,
Maybe you should update your "helping document"… 😄
(5,270 Views)
done Smiley Happy
the folder was there but the content not 100% the same as before.
(5,266 Views)
