Ni 9263 sometimes outputs 16.6mV independent of the specified voltage and unrelated outputs for low timing rates around 10 kHz
I have a problem about Ni 9263. I am applying a continuous analog output(dc voltage) from Ni 9263 and measuring that using Agilent 34401a via GPIB.  Sometimes, Ni 9263 couldn’t write the specified value and I read 16.6mV from Ni 9263 whatever the specified outputs are (I checked ithat value with multimeter at the output of Ni 9263). Also, if I decrease timing rate around 10 kHz, Ni9263 results in unrelated output voltages. Is there limitation for NI 9263 timing rate (other than max update rate is 100kS/s) or is there something that I am missing?
I attached the vi which is very simple. Also, I tried same thing with Ni9264 and same problem which makes me suspicious about my vi.
Thanks for the response in advance.
Ouz
NSC
(3,334 Views)
Is there anyone who has an idea or suggestion about this problem?
Ouz
NSC Intern
(3,322 Views)
It is possible that there is a hardware problem - the AO can supply 1mA so it has to drive a high impedance device - if only the DMM is connected this shouldn't be a problem but if another device is switching in and out it may keep the output near ground when it's switched in.
Did you try using MAX to set a fixed output voltage and does that always work?
Jim
(3,314 Views)
Accepted by topic author ouz
Hi Jim,
Thanks for your response. I have connected the DMM directly to the Ni9263 and I have also checked with MAX and it works as expected.
Finally, I solved the problem thanks to one of Ni forum post in 2007 http://forums.ni.com/t5/LabVIEW/Analog-Output-Buffer-Size/td-p/612858 . As explained here, we couldn't use Timing for DC constant value.  Maybe, this will be helpful for others.
Ouz
(3,278 Views)
