Ni-DAQLV error -10243, error-10008 & error-10401
I am using labvirew6.0. I have the following errors "Ni-DAQLV error -10243, error-10008 & error-10401" Do I need to install the latest drivers on my system?I still want to use labview6.0?
(3,869 Views)
Anyone can help?
(3,854 Views)
Hello LV1958
Which version of NI-DAQ do you have on your system?
(3,844 Views)
I am using LV6.0. The 6025E-DAQ card was install in 2001 by someone else. How do I find out which version?
(3,840 Views)
I would suggest installing NI-DAQ 7.1 which is the latest that can work with your version of LabVIEW.
(3,827 Views)
Hello I am using labview 7.0, Max 3.1.1.3004 and i am having the same problem. We currently have two pc's running labview 7.0. This system is step up with one pc as the main controlling pc and the other pc mainly collect data and transfers it to the main pc. PC1 is the main controlling pc and PC2 is the data collecting pc it has a daq card 6025E and two 6527 cards.
The 6025E is used to collect and monitor transducer and collect pressure readings. The 6527 are you use to trigger I/Q points to open and close doors, trigger LEDS and other functions on our system. This current system works fine. What we are attempting to do is recreate a complete back system, the PCs.
This Code written by a third party and we no longer have them as a resource. The un-complied code is broken up into to sections one set of code is for PC1 and the other set of code is for PC2. So we took the un-complied code for PC1 and complied on what is going to be our back up PC1, all went good and the back for PC1 is ready. Here is where we run in problems. We took the un-complied code for PC2 and complied it on back up PC2.
BackUp PC2 contains one 6025E card and two 6527 cards.  When we try to run the EXE file we get a 10001 only if a file called niconfig.daq is within the folder containing the exe file. When I remove this file called niconfig.daq, we now get 10243 error code. Since we are unable to contact the original programmer I have not clue it that niconfig.daq file needs to be there or not.
How do you read a .daq file anyway in text pad it's unreadable.
 Error code 10243 says occurred at DIO Port Config, I can find that .vi within the code but how do I know what needs to be changed in that .vi,  DIO Port Config  is a labview pre-built vi and not a customer vi. any ideas of what that could be?  I saw the post suggesting the  driver update i will try that and let you know if it fixes the problem.  anyone have any ideas?
FYI  lvdaq.dll 7.256.3.1 is also complied and place in the same folder with our EXE
(3,732 Views)
Dear AdamJ,
To run any Traditional (Legacy) DAQ program, your computer needs to know where to find niconfig.daq. The person who created the executable added it to the folder of the executable, so your computer would find it. The error 10243 that you are getting without niconfig.daq just says that your program can't find this file.
As for the other error you are getting, it appears that you have the channels labeled incorrectly for AI Group Config.vi. On the block diagram right click on the VI and select Help. Make sure that you are labeling all of the input correctly. There might be something else going on in the background, so I recommend installing DAQ on PC2. This will install niconfig.daq in C:\WINDOWS so you won't need it in your exe file. I would then go ahead and delete the .daq file from your exe file. Have a great day!
Sincerely,
Marni S.
(3,706 Views)
