Ni PXIe-4492 connects to oscilloscope
My NI-PXIe 4492 device is in the case of NI 8821. When I connect one of the channels of NI-PXIe 4492 with the probe of the oscilloscope, the oscilloscope does not show the waveform. I want to know why, and what can I do to fix it. Thank you very much!
Message 1 of 8
(1,507 Views)
For your information, PXI 4492 is an Analog input module, you need a signal generator to provide signal to the module. Connecting two inputs together will not give any signal - 4492 and scope.
Santhosh
Soliton Technologies
Message 2 of 8
(1,489 Views)
I think I understand. Thank you so much for your answer!
Message 3 of 8
(1,462 Views)
As you explained, I've been looking for a lot of ways to do this, but it may be a little difficult for me, the problem is not solved, I would like your advice, you think if I want to use the oscilloscope connection NI 4492, what am I supposed to do? Thank you very much!
Message 4 of 8
(1,411 Views)
4492 is an analog input card, it consumes signals like an oscilloscope.
Always connect a signal output to signal input. You do not connect two inputs together without a signal output as it does not logically provide any functionality.
Please elaborate on why you would need to connect a scope to 4492 and what you have tried.
Santhosh
Message 5 of 8
(1,406 Views)
I tried to connect the oscilloscope to the NI 4492 because when NI 4492 was used for data acquisition, I wanted to be able to display the 4492 results on the oscilloscope. The eight channels are supposed to connect the signal to be collected, so I don't know how to connect the oscilloscope to observe the waveform when the 4492 is collecting the signal.
Message 6 of 8
(1,397 Views)
Please share details of cables, connectors used in the connection and if possible picture of the cable connections.
Where does the signal come from? a microphone or accelerometer? what model?
What kind of oscilloscope probes do you have?
Santhosh
Message 7 of 8
(1,391 Views)
我还没有接信号,我只想知道,以后我要采集数据的时候,NI 4492通道接了信号,如果要外接示波器怎么接?附上我目前组装的硬件设备。
Message 8 of 8
(1,383 Views)
