Ni_database "show data"
I've made some data logging; now I read from DB with block "NI_database". What I want is to show these data in one table...
My data output is 2D; For now I have just "data block" but is not OK (I need just one table, to see all data at once-or just last one wit automaticall scrolling)
_________________________
Rookie; LV 2011 on WIN 7
Message 1 of 12
(3,092 Views)
You can place a Database variant to data with a 2D string-array as type input to get a 2D string array instead. It makes for nicer presentation.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 12
(3,088 Views)
Yes,yes I get this, but still is not automatically scrolling down(while new data coming into table...); I'm searching at properties for this, but not found;
Message 3 of 12
(3,085 Views)
Ah, you want to watch the last row? Then you'll need to use the Scroll Position property and set it to Infinity when an update occurs (or at regular intervals).
/Y
Qestit Systems
Message 4 of 12
(3,075 Views)
No I want to watch whole data as now; but aways refreshing last row, to see what's happening; now is "stuck" while i go manually with mouse to button.
Message 5 of 12
(3,071 Views)
The table is updated every time you perform your Select query, do you use a while loop or event structure?
/Y
Qestit Systems
Message 6 of 12
(3,065 Views)
I use while loop; You don't understand me; The table is refreshing OK, but after a lot of data, I must scroll down manually, I want that labview will scroll down automatically with new data...
Message 7 of 12
(3,063 Views)
Anyone else ??
Message 8 of 12
(3,049 Views)
You got the answer already with the scroll position property. Did you even try it?
Message 9 of 12
(3,046 Views)
Well I tried this, but I never use "property node"; Can you make little example, please?
Many thanks for your time
Message 10 of 12
(3,040 Views)
