NiDaqmx with Python
I want to use NIdaqmx with Python. Followed the procedure .But after completing installation, when I am testing it, it just seems to not doing anything, as in the attached screenshot. Can anyone give me a clue about what may be happening here?
Thanks in advance
(3,639 Views)
(3,603 Views)
Shouldn't that second line by task.add ......   and not task_ai_channels.add  ...   ?
(3,573 Views)
Thanks for your reply. Tried but did not work.
But I was finally able to run it by changing task_ai_channels  to task.ai_channels
(3,558 Views)
Accepted by topic author maccapple
And that is exactly what I said, but just flipping it around.
I said shouldn't it be  (but I typed "by" by mistake) task.add ...... and not task_ai_channels.add ...
And you said "I was finally able to run it by changing task_ai_channels to task.ai_channels"
So you did exactly what I told you to do!
(3,473 Views)
Oh.Ok. I did not realize that.
Thanks for your help.
(3,467 Views)
