12-24-2015 12:05 PM
Good evening,
I installed LabVIEW 2015 on my personal machine.
I want to work with a project developed on LabVIEW 2013 on a CompactRio.
The problem is that when I want to open the VIs containing FPGA methods, I get the following message: Error Loading "NiFpgaLv.dll". A dynamic link library (DLL) initialization routine failed.
I get this message multiple times (around 20 times) while loading the VI. Then it is impossible to run the VI.
I have never connected the CompactRIO to this laptop but only to the office PC (running LV2013).
If you have any suggestion, please let me know.
Best,
Andrea
12-24-2015 12:35 PM
Did you install the FPGA module or the NI-RIO tools after installing LabVIEW?
12-24-2015 06:49 PM
12-24-2015 09:48 PM
Okay. I had to ask because many people will forget there is more than just LabVIEW.
Perhaps try reinstalling in case something didn't install properly. But otherwise I don't have any ideas.
12-27-2015 10:54 AM
Thanks anyway.
If it can help, I can see open my VI without problems but the execution gives the following error:
So the error is in Open FPGA Reference File, which points to a compiled bitfile which is present on my computer.
The file is there at the correct path, so I don't understand where the error might come from.
I could try recompiling but it takes 7 hours or more, so I would like to avoid it if possible.
If somebody is able to help I would be very thankful.
Andrea
09-27-2019 02:31 PM
Has someone discovered a solution or a work-around to this issue?
I have tried compiling the FPGA, and creating a stand-alone exe file, however I get the same error message if I try to run the exe file on a computer where 2015 SP is not loaded.
