NiSwitch Issues
I have an 1163R module and I'm trying to write a simple VI to connect one channel, wait a certain time, disconnect that channel, then wait a certain time.
I'm building my VI based off the include niswitch examples, but I'm still getting a problem.  When I run my attached VI trying to connect ch12 to com3, I get:
"Error -1074130544 occured at niswitch disconnect channels (single).vi
Possible reasons: Invalid value for parameter or property.  Channel cannot be NULL or empty"
I'm pretty sure this is just a Labview software issue and not anything wrong with my hardware.  I've attached my VI that's giving me issues.  Any help would be appreciated.
(3,372 Views)
Your issue is that you aren't running your instrument handle through the shift register in sequence 1 of the stacked sequence structure.  Therefore when sequence 2 executes the handle coming out of the shift register is empty, hince your null error when trying to disconnect your two channels.
(3,349 Views)
