Nibp
I read Nibp signal from daq assistance
The problem with the rate of sampling and the freqancy ,I used vernier nibp sensor
What is the best value to make my sample lenght is 30s?
(2,566 Views)
I don't know what nibp is but I don't see how it is relevant to your sample length question. It's simple arithmetic. # samples divided by samples per second gives you seconds. For example, you request 500 samples at a 1000 sample/sec rate. That will take .5 seconds. Execute the loop 60 times - appending the new samples to the old if desired or save each acquisition as it happens.
(2,547 Views)
