No Data with Scan Interface in cRIO 9024 Windows 10, HELP!!!!
Greetings to Everybody!!!
I recently acquired a cRIO-9024 with Ni 9225, NI 9227 AND 3 MODULES OF NI 9219, I read all of the datasheets and i know how to connect them,, i put some Voltage in it ,for thtarget to  read something, and it's not procesing the data
I have a DESKTOP - HIC1MN4 LENOVO with MICROSOFT WINDOWS 10 HOME SINGLE LANGUAGE,
Therefore i could not install the Xilinx or Vivado tools for compile, but i did install Labview FPGA Module, and it let me to install it, even if
it is not compatible with WIN 10
So.
Few Questions :
Is it true that there is not any way to campile locally the FPGA (Because i dont have vivado or Xilink0?
I followed this next tutorial for Compact rio
https://www.youtube.com/watch?v=ksaeXq84PAg
i did my VI , is it right like this ?
i'm only using Scan Interface.. for compiling it
I appreaciate the time of all of you spended in Understanding and helping me to solve this problem,
(2,450 Views)
Try putting an error indicator on each one of the variable reads you are doing. I would suspect that there is an error that is not being caught.
(2,422 Views)
