No GPIB connection, but visible in MAX
The device is visible in MAX, but I am unable to communicate with it, either by using the 'Communicate with Instrument' or the 'VISA Test Panel'.
This seems slightly sporadic, as I have once or twice been able to connect and send a successful ID query (It's too old for *IDN? ...). However, even if I reach this point I either then get error 0: not able to connect to device/driver or error 6: timeout within Labview, and then I am unable to do anything in MAX after that point.
I have tried disabling timeout, switching cables, turning everything off and on again all to no avail.
This is very frustrating as with my standard setup I have not changed any VI's, settings, cables or anything since it was working fine earlier.
Cheers for any input.
(3,734 Views)
Which GPIB adapter are you using?
(3,722 Views)
And what's the instrument? Something so old that it doesn't support the idn query may have a hardware failure. Have you tried replacing it with a spare?
(3,717 Views)
Sorry, I forgot to mention, its an NI GPIB-USB-HS.
I also have the same problem (minus any instances of error 0) with an EG&G 5210 Amplifier.
(3,705 Views)
It seems like I accidentally deleted the first paragraph of my initial post, the instrument I'm currently having problems with is an EG&G 5207 Lock-In Amplifier.
(3,704 Views)
For older instruments you may have to resort to NI-488.2
I had some old HP counters that did not "play nice" VISA.
(3,694 Views)
Sure, I'll see what I can find and if it helps at all.
Interestingly, today the 5210 connected fine and I was able to test some new code and everything worked perfectly...
(3,665 Views)
