No Remote access to Executable
I want to run .exe on remote PC.
I created an .exe from VI. Then I try to run .exe file on remote PC.
See the attached error.
But able to run VI rather than .exe.
Please let me know, how to over come this.
VI directory :D:\jey\Test.vi
.exe directory :D:\jey\Test\Test.exe
On Client PC, What "VI Name" I supposed to call.
Test.vi or Test.exe
Thanks for help
Jey
(2,695 Views)
Jey:
Thank you for contacting National Instruments. The way executable work is that you create a VI on your development machine and then create an executable for that VI. Once the executable is created, you can run it on other computers provided that they have the LabVIEW Run-Time Engine (RTE) installed on their machine. Once the RTE is installed, you should be able to click on the ".exe" to run it. Also, are you viewing Remote Front Panel?
I hope this helps and let me know what you find.
Rudi N.
Message Edited by Rudi N on 11-15-2006 02:07 PM
(2,688 Views)
