No classes in class hierarchy view
Hello community,
since I have opened and play around with the actors framework my class hierarchy window is clean (LV2011). LabVIEW is crashed a few times I made some changes to the framework. I hope I can fix it with your help.
Best regards, Andreas
(2,679 Views)
Does a "ctrl a" make a difference?
You may want to post the project and all files to let R&D to have access. When last I heard, they were looking for examples that would duplicate the issue.
Ben
(2,667 Views)
Thank you Ben for your solution. No it is no difference when I push "ctr a". This problem occures with every project including lv classes now.
Andreas
(2,652 Views)
I was unable to edit my post. Sorry for that. I tried to repair my labview installation. This do also not solve my problem. Has someone with additional idea?
(2,647 Views)
