No com-ports with run-time engine.
I have a LabView program that opens a connection to a virtual com port and uses it to connect to embedded hardware. I search through the com-ports by applying the string "ASRL?*INSTR" to VISA Find Ressource and then find the ressource that maches USB-to-Serial.
And it works just fine on my own PC.
Now I have installed a LabView run-time engine on a new PC, and when I try to run my program on the PC with the run-time engine it cannot find any com-ports at all...
Do you have any idea where I should start to look to solve this?
//Stephan.
(2,683 Views)
Stephan,
i am quite sure that you missed to install the VISA-runtime engine on the target PC as well.....
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(2,682 Views)
You are right.
I forgot that it had a seperet installer...
Thanks.
(2,679 Views)
