No-contact liquid height measurement
I need to measure the height of a liquid in a tank. A sensor that does not contact the liquid is prefferable. The sensor has to measure (approx.) 1/2 inch to 1 foot with at least 1/8 inch resolution. Any suggestions?
Message 1 of 11
(5,081 Views)
Accepted by topic author S-T-G
Keyence?
Ben
Message 2 of 11
(5,080 Views)
That would have been my answer too.....
Shane.
Message 3 of 11
(5,071 Views)
If this is a school project perhaps some sort of electronic weight, or load cell may be used. Given that your container is uniform of course. But I admit this solution may be somewhat awkward in other settings
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 4 of 11
(5,064 Views)
Depending on the size / shape / connections on your tank it might be possible to weigh it.
I know of many processes where the contents of a tank are monitored by simply having the tank sitting on a weighing scale.... That's also not contacting the liquid and is probably a lot cheaper than a keyence sensor.
Shane.
Message 5 of 11
(5,061 Views)
In terms of technology (besides weight, which is always good and easy), two other methods come to mind:
1) Acoustic
2) Fiber-optic
Are there any other constraints in your measurements?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 6 of 11
(5,013 Views)
Take a look at hydepark ultrasonic sensors or ifm efector. Keyence also has an ultrasonic as well.
http://www.sesensors.com/content/en/products/ultrasonic-sensors.asp
http://www.ifmefector.com/ifmus/web/padv02_30_10_10.htm
http://www.keyence.com/products/sensors/ultrasonic/fw/fw.php
Does the liquid have any foam in top?? Foam can cause some trouble with the ultrasonic sensors. Submersible pressure transmitters can also have problems if they get clogged up on the screen.
Message 7 of 11
(4,986 Views)
Another constraint (& partly the reason for non-contact), the liquid in the tank will be heated to 105 degrees C.
Message 8 of 11
(4,973 Views)
That's a really big constraint. The heat coming off of that will probably melt an ultrasonic sensor. Sounds like weighing the tank might be the best option. Use a load cell underneath the tank. How large is the tank??
Message 9 of 11
(4,970 Views)
Try Endress & Hauser. Look at level and radar systems. Probably not very cheap though. Temps up to 700 degrees F.
http://www.us.endress.com/
Message 10 of 11
(4,964 Views)
