No daqmx vis in measurement i/o in Labview 8.5 after install
Labview 7.1 also resides and can them. How to fix for 8.5? Running NiDaq 8.7.1 Tried copying Daqmx folder from vi.lib under program files\7.1 to 8.5  Tried same for Nidaq Mx.mnu under menus\default. Also for folder daqmx under menus folder. Any ideas?
(2,975 Views)
When you installed LabVIEW 8.5, did you then run the NI-DAQmx installer?  In order to get DAQmx support for a newly installed version of LabVIEW, you'll need to run the installer again so that the installer can add support.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(2,971 Views)
Accepted by topic author Macl10
I installed 8.5 along with 8.7.1 drivers that were on the same disk(DVD). I was using 8.7.1 with LV 7.1 I'll try re-installing drivers from a separate Nidaq disk
(2,965 Views)
Thanks Seth. That fixed it. i was suprised though since I set the install to install drivers when i installed 8.5. Guess it still needs to after the fact.
Thanks again
(2,952 Views)
