No data output field in DAQ Assistant
I am currently trying to read temperature from my NI WSN 3202. I have a thermistor connected to AI0 and AIGND.  I am following a tutorial to convert from volts to degrees F and everything has been working so far.
Once I reach the step for DAQ that is when I have issues.  I've created a simulated device (following another tutorial).  When I configure everything for DAQ, there is no data field so that I can wire it to my indicator and then to the formula block.  Can anyone assist me with this problem?
Pictures have been included. (The picture that has the data field is what I'm trying to get to)
Thank you in advance!
(2,306 Views)
I would do as the error message tells you, reinstall DAQmx.
GCentral
(2,299 Views)
