No file dialog in execuatble
I have an urgent problem.  I have installed labview 8.0.1 in a new computer.  I mass compiled all filles.  The problem is, when I build an executable for a different machine, the executable SKIPS THE FILE DIALOG BOX.  The VI just ends.  I recall something about needing to press ctrl+run when recompiling old VIs (which I did) but I need some quick help on this one.
(3,396 Views)
Hi anstech,
what is your code like?
Ton
My LabVIEW Ideas
(3,381 Views)
(3,365 Views)
anstech,
I was able to successfully build a VI with just the file dialog VI.  Can you build an EXE with just the file dialog VI?  I assume that your VI does work when you run it in through LabVIEW, correct?  I was able to build and run your VI and received a file dialog when I did so.  If you want to recompile the VI you can always press Ctrl+Shift and click the Run button.  Have you tried using the Debuggable EXE option?  I would suggest trying this if you haven't already, that way you can keep track of the data with probes/highlight execution.  Let me know how this goes.
Thanks!
Andy F.
Message Edited by Andy F. on 10-17-2006 02:45 PM
(3,356 Views)
AHA!!! ctrl PLUS shift and run, I only pressed ctrl run.  I'll try that tomorrow and let you know if it worked. (Hardware unavailable today)
THANKS
(3,347 Views)
