No menus , locked out of editing, any way to fix?
I have a VI, that I did not create, that, when opened, starts running and there are no Labview buttons (run, stop, pause, etc.) and no menus (file, edit, window, etc.) If I stop the program, it closes labview. Is there a backdoor to get into the block diagram, I would guess no, but>....
(2,755 Views)
Try to stop your vi using the utility below.
http://forums.ni.com/attachments/ni/170/100926/1/StopAnyVi.vi
CC
Chilly Charly    (aka CC)
(2,752 Views)
Without using external code you have another two simple options. One is to use Ctrl+., which is a shortcut for the stop button, but won't help if the stop button was set to be hidden. The other is to open a new VI and drop this VI in that VI. Now, you can open it by double clicking it.
___________________
Try to take over the world!
(2,748 Views)
I am curious..
This Labview vi that you are trying to open, is it:
a) an editable vi, in other words : viname.vi (vi extention)
or
b) an executable vi, in other words : viname.exe (exe extention)
JLV
(2,745 Views)
Thanks, dropping it in another vi worked..
Marty
(2,738 Views)
