04-11-2005 06:36 AM
04-11-2005 07:29 AM
@ramiral wrote:
I don't anderstand how can I do my programm because I read that we must not use 2 events structures in one loop. But concerning my programms for instance I have to fill arrays only when I press each appropriate "Ok" button (for instance for 5 case I have to press 5 different OK button ) and so on (when I press OK number 6 the program write to excel program.. when I press OK number 7.. )
How can I do it? I need to create 7 events structures for 7 actions?
04-11-2005 07:38 AM
04-11-2005 08:49 AM
04-11-2005 09:07 AM
You need one event struture that handles seven different events. If there is code that is common to all events, it should be outside the event structure, but inside the while loop.
04-11-2005 09:27 AM - edited 04-11-2005 09:27 AM
Message Edited by ramiral on 04-11-2005 09:28 AM
