No option RT FIFO for Shared Variables - LabVIEW 2023 Q3
Hello!
I faced a strange behavior in LV2023Q3 creating real-time shared variables. There is no option to turn on RT FIFO. Here's how it looks on a PC running LabVIEW 2020 SP1 - more options for variables, and RT FIFO among them. And a significantly shorter list in LabVIEW 2023Q3 with no RT FIFO at all. Everything necessary is installed (I use an academic license with full set of modules included). And I double-checked on two different PCs - same thing. What could be the cause?
(3,835 Views)
Same for me, any progress on that?
CLA
(3,758 Views)
It looks like you have the LabVIEW DSC and Real Time modules installed on LabVIEW 2020 SP1. That is why you see the extra items for the Shared Variables.
(3,741 Views)
Hello amayzel2
Not sure if you've already solved this but just in case someone encounters this same problem:
This is a bug from LabVIEW 2023 Q3 Patch 1 and was solved in LabVIEW 2023 Q3 Patch 2. You can go to the NI Package Manager and select LabVIEW 2023 Q3 and it should install the Patch 2 and fix the bug.
Source: https://www.ni.com/en/support/documentation/bugs/23/labview-2023-q3-bug-fixes.html
(3,381 Views)
You show that your Real-Time Target is a myRIO.  Have you installed any version of the myRIO Software Toolkit?  As far as I know, the two most recent versions are myRIO Software Toolkit 2019 and myRIO Software Toolkit 2021.  Do you have any myRIO support installed on your LabVIEW 2023 system?
Bob Schor
(3,282 Views)
