No option to convert control to class
I got fairly deep into a project here and realized that I really ought to make one of my controls into a class (I want to flatten it to an XML file to save it, and unflatten to load even if the control has been updated).
I was under the impression that it should be fairly straightforward, according to the help file on the subject, but when I go to the project explorer and try to right-click the control, I get no such option.  Not even greyed out.  See attached picture... I censored some file names for company confidentiality but the right click menu and project explorer are visible.
I am using LabVIEW 2011 SP1 on Windows 7 64-bit.
I am using this control in 37 VIs according to the "find callers" option so I am really hoping to not have to manually replace it and all of the wires to it in every single one.
Any ideas?
(3,251 Views)
It might be a Win 7 64 bit version issue. Check this feature availability in LabVIEW 2011 64 bit version.
I was able to view the option in LabVIEW 2011 under Win 7 32 bit OS.
(3,223 Views)
Well Im 72 hours old to labview ( still have other programming experience ) and Im not at the point of converting controls to classes but i really think there are missing infos for resolving this case.
- Are all the controls in your list giving you the same problem ? ( Still dont have the option when right-clicking on them ? )
- Is your control a cluster of other controls ?
- Does it contain x-controls ?
- Is it a private control ?
- Is your control locked ?
4G
4GForce
(3,216 Views)
Not a single one of my controls can be converted to a class.  Even if I create a new project and a new control with just a couple things in it.
The control in question has a bunch of other controls in it (7 enums, 3 U8s, 2 booleans, and a string) as well as an array of strings and 3 arrays of other custom controls.  But seeing as how even the most primitive control doesn't work, I don't think this is the issue.
The control and all sub-controls are currently strict typedefs, but like I said, any new control with just one numeric in it also has this same issue, so this is also probably not the issue.
No x-controls.
The control isn't part of an existing class, so it's not private.  It nor any control it contains is locked.
I checked, and despite being a 64-bit version of Windows 7 the LabVIEW version I have is 32-bit.
(3,197 Views)
If you are sure it is not a "Controls" and Windows 7 OS issue, try repairing the LabVIEW.
(3,184 Views)
I tried a few more things, none of them worked.
Eventually I just gave up on having the menu option show up, and I made a new class, and populated it's provate cluster with a copy-paste of all elements of the original control.  Then I removed the cluster from the control, and put the new class in there instead.
Then I did all of the conversions, after making some new accessors.  Took about 3 hours to fix the 37 broken VIs...
(3,144 Views)
