My data aquisition worked fine until I calibrated the channels. I am reading 60 analog voltages (0-5vdc) from a pci-6225 using DAQ Assistant. After the calibration my program still ran but DAQ Assistant is not outputting any values. I tried probing the line on the output but I see nothing. The program thinks it is sending the data to file but the file is blank except for the header. When I turn off calibration it works fine. Any ideas about what I did wrong?
