No path or empty path can exist?
Hello!
There is this LV internal VI to check if a file/folder exists, which would return a boolean. When opening the front panel, the path box is empty. When running the VI, see below, it would return TRUE, meaning the not given path exists. That makes me wonder what the definition of the existence of a file or folder is...😮
Message 1 of 15
(5,480 Views)
The empty path is in LabVIEW indeed a valid path for some functions.
It is in fact the root to all paths. Under Windows this is the (virtual) path in which all the drives are located. Under Unix this is the root path itself "/".
If you use for instance List Folders with an empty path as input you get under Windows all the valid drive letters, and under Unix all the top level directories. Under Mac with HFS you got all the Volumes on the desktop but HFS is not used anymore in LabVIEW for Mac since the demise of the 32-bit version of this with LabVIEW 2017. The 64-bit version of LabVIEW for Mac always used Posix style paths, just as the Linux version.
So in summary the Empty Path definitely is a valid path in LabVIEW as it is the root of the file system/desktop.
Rolf Kalbermatter  My Blog
Message 2 of 15
(5,478 Views)
For future reference, you can also find this info in the help file.  And if you think rolfk copied that response from the help file, you would be wrong.  In fact, quite the opposite.  The help file was written based on information in rolfk's brain.
aputman
Message 3 of 15
(5,436 Views)
OK, but you would want to use the VI to find out if a file or folder exists, and no path given is not an existing folder, no matter how LV interpret an empty path. At least in this case the LED shouldn't light up. I will modify the VI now.
Message 4 of 15
(5,389 Views)
I don't understand this statement.  Wouldn't you just use billko_0-1678284533503.png ?
Bill
CLD
(Mid-Level minion.)
Message 5 of 15
(5,367 Views)
If you don't want to allow empty paths, just do a check for them using the comparison function "Is Path and Not Empty?"  The underlying code for the "Check if File/Folder Exists" can't be modified.  That is the "File/Directory Info".  So now you will have one function that returns false and another function that returns true for the same request.  Makes zero sense but you're certainly allowed to do stupid things.
aputman
Message 6 of 15
(5,358 Views)
I guess I just never really understood the whole topic because I always make sure that by the time it gets to this point, we aren't looking at an empty path.  Not that it wasn't a valid concern; it was that because of my workflow, it never occurred to me that someone would be trying to do a check with possibly an empty path.
Bill
CLD
(Mid-Level minion.)
Message 7 of 15
(5,339 Views)
I agree with you.  I just think it's a stupid decision to modify core LabVIEW code when there are tools to make sure an empty path is avoided.
aputman
Message 8 of 15
(5,327 Views)
I think what you want is something like this...
Adjust the last AND input as required.
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
Message 9 of 15
(5,280 Views)
That's pretty much what I would do, except if you look in that Check if File or Folder exists, there already is a File/Directory Info inside and if you do not need the ability to detect files inside LLBs, you might just do this function once. It is not a huge performance killer to call it twice, but he LLB enumeration is and you do not want that function really get called in a tight loop as that for sure can make everything very slow.
Message 10 of 15
(5,271 Views)
