No permission to uninstall built application
I built and executable and an installer for it which I have done before without issue.  I installed on another machine without issue.   I found an error with that I had so I wanted to unistall it.  The PCs uninstall shows it on the list but said I do not have permission to uninstall it.  My network admin said I do.   Could this be a Labview issue?   I have the latest 2013 pro version.  Both computers are win 7 enterprise.
(2,706 Views)
try restarting the machine.  See if that takes care of the problem.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(2,678 Views)
Hey bobausttex,
I have found a Support article that could help resolve your issue.
Uninstalling LabVIEW-Built Installers Silently:
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/uninstalling_silent_installers/
You might have to try this while running the Command Prompt in Administrator mode.
Hope this helps!
Robert R. | Applications Engineer | National Instruments
(2,669 Views)
I dont think its a labview issue? Are you in admin mode?  Please check once again?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,660 Views)
I am fairly sure now this is not a Labview issue but local to the machine.
Thanks for playing.
(2,636 Views)
