No" My system" in my MAX interface
Hi i am currently using MAX interface and i encounter this kind of problem, does anyone know how to solve? Please reply as my company is urgent in this matter. Thanks for advices in advance!
(2,543 Views)
Besides MAX, What NI software do you believe you have installed?
(2,535 Views)
I have installed Labview 2009 which comes together with MAX, and NI Device Drivers which is for communication of the devices. What is this phenomenon indicated? Was I installed something wrong? Or what else i havent installed?
(2,531 Views)
It indicates you got a bad (possibly corrunpted) installation or a firewall is not allowing MAX to communicate via TCP/IP socket between the NI services on the machine.  If your SSP is up to date I would open a service request and send a technical support report from MAX (FILE>Create Report...)
(2,512 Views)
Did you install DAQmx, or just some other device drivers (for example NI-VISA)?  If so, try installing DAmx.  That fixed this problem for me, although I don't understand why DAQmx should be needed on a system that does not have any DAQ devices.
(2,502 Views)
