When running a LabVIEW application on a computer without the RunTime engine, nothing happends.
No error, no program start, no window showing the VI, nothing. Normally you will get the "RunTime engine not found" error ?
After running the installer and thereby installing the RunTime engine, the application functionate ok.
Thanks for your help
Bjarne Jakobsen
