Refering to the attached images, i have a VI using serial port which i have already programmed in 1 PC. After i've installed LV and DaqMX on the 2nd PC and try to run this VI, it doesn't work. Then i realised the 2nd PC does not have Serial port detected at MAX->Devices.
What could be the problem?
I'm using LV 8.2 eval and DaqMX 8.5
